41-221c
Kirk (OldRestorer) had several of these grills made. He did have an ad in the For Sale or Trade section of the Phorum (bottom of the page on the Phorum home page), but the ad is no longer there so he may have sold them all?
41-221c - by nortonz - 06-04-2018, 11:16 PM
RE: 41-221c - by Ron Ramirez - 06-05-2018, 06:15 AM
RE: 41-221c - by OldRestorer - 06-05-2018, 12:48 PM
RE: 41-221c - by nortonz - 06-05-2018, 01:05 PM
RE: 41-221c - by OldRestorer - 06-06-2018, 09:21 AM
RE: 41-221c - by sam - 06-06-2018, 01:22 PM
There are currently 5757 online users. [Complete List]
» 1 Member(s) | 5756 Guest(s)
