Three GE Transistor Radios
#41
(05-27-2018, 06:18 PM)35Z5 Wrote:   GE did offer a rarely seen adapter to fit six AA in place of 9v.
I found one of the illusive little critters..
Was in poor condition, had to replace or rebuild all the battery contacts, but it works. Without the outer shell, batteries would easily dislodge from the holder.
Tom
Three GE Transistor Radios - by Jayce - 03-12-2018, 04:46 PM
RE: Three GE Transistor Radios - by David - 03-12-2018, 07:32 PM
RE: Three GE Transistor Radios - by Jayce - 03-12-2018, 09:47 PM
RE: Three GE Transistor Radios - by David - 03-13-2018, 07:47 AM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 09:51 AM
RE: Three GE Transistor Radios - by Jayce - 03-13-2018, 05:10 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 08:55 PM
RE: Three GE Transistor Radios - by Jayce - 03-13-2018, 09:15 PM
RE: Three GE Transistor Radios - by David - 03-13-2018, 09:19 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 09:51 PM
RE: Three GE Transistor Radios - by Arran - 03-14-2018, 12:07 AM
RE: Three GE Transistor Radios - by 35Z5 - 03-14-2018, 11:28 AM
RE: Three GE Transistor Radios - by Jayce - 03-14-2018, 12:12 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-14-2018, 05:11 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-19-2018, 05:02 PM
RE: Three GE Transistor Radios - by Jayce - 03-19-2018, 10:11 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-19-2018, 11:42 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-30-2018, 05:49 PM
RE: Three GE Transistor Radios - by Jayce - 03-30-2018, 11:51 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-31-2018, 08:39 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-02-2018, 08:03 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-05-2018, 09:48 AM
RE: Three GE Transistor Radios - by Jayce - 04-06-2018, 10:06 PM
RE: Three GE Transistor Radios - by 35Z5 - 04-07-2018, 12:02 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-08-2018, 10:46 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-12-2018, 08:46 PM
RE: Three GE Transistor Radios - by Jayce - 04-12-2018, 10:13 PM
RE: Three GE Transistor Radios - by 35Z5 - 04-18-2018, 11:51 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-25-2018, 06:34 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-05-2018, 03:40 PM
RE: Three GE Transistor Radios - by Jayce - 05-05-2018, 04:45 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-05-2018, 11:25 PM
RE: Three GE Transistor Radios - by jcassity - 05-12-2018, 08:20 AM
RE: Three GE Transistor Radios - by 35Z5 - 05-27-2018, 06:18 PM
RE: Three GE Transistor Radios - by sam - 05-27-2018, 06:45 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-30-2018, 06:02 PM
RE: Three GE Transistor Radios - by Jayce - 05-31-2018, 12:18 AM
RE: Three GE Transistor Radios - by 35Z5 - 05-31-2018, 10:23 AM
RE: Three GE Transistor Radios - by Jayce - 05-31-2018, 02:54 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-31-2018, 09:26 PM
RE: Three GE Transistor Radios - by 35Z5 - 06-05-2018, 04:40 PM
There are currently 9936 online users. [Complete List]
» 3 Member(s) | 9933 Guest(s)
