An RCA 140
The radio was using a 6a6 for an output in place of the type 53. It's basically a six volt type 53. Pinout is the same and everything. Sadly, the question to keep this radio six volt or not has been rendered moot. The input transformer or power transformer is shot and will need to be replaced. Since I will be getting the same transformer for mine and the repair guy who also has a chassis like mine, we will be going back to the 2 volt type. What is it about some models of radios and their eating transformers? This one was replaced in 1945, so one would have thought it would be good, but it is shot. And this type of RCA chassis does seem known for bad transformers. Icon_sad
An RCA 140 - by exray - 09-28-2010, 08:41 PM
Re: An RCA 140 - by exray - 09-28-2010, 08:46 PM
Re: An RCA 140 - by Ron Ramirez - 09-28-2010, 08:58 PM
Re: An RCA 140 - by exray - 09-28-2010, 09:37 PM
Re: An RCA 140 - by Alan Douglas - 09-29-2010, 06:34 PM
Re: An RCA 140 - by denver - 09-29-2010, 07:53 PM
Re: An RCA 140 - by Jayce - 09-29-2010, 11:17 PM
Re: An RCA 140 - by exray - 09-30-2010, 09:46 PM
Re: An RCA 140 - by Jayce - 10-02-2010, 09:07 PM
Re: An RCA 140 - by Ken G - 10-11-2010, 08:05 PM
Re: An RCA 140 - by Allen in SB - 10-17-2010, 12:51 AM
Re: An RCA 140 - by exray - 10-17-2010, 07:07 AM
Re: An RCA 140 - by Jayce - 10-17-2010, 05:15 PM
Re: An RCA 140 - by Doug Houston - 11-23-2010, 01:30 AM
Re: An RCA 140 - by Jayce - 11-23-2010, 06:06 PM
Re: An RCA 140 - by exray - 11-24-2010, 08:19 AM
Re: An RCA 140 - by Jayce - 11-29-2010, 06:27 PM
Re: An RCA 140 - by FStephenMasek - 12-01-2010, 11:48 PM
Re: An RCA 140 - by Jayce - 12-02-2010, 03:38 PM
Re: An RCA 140 - by exray - 12-02-2010, 04:40 PM
Re: An RCA 140 - by Ron Ramirez - 12-03-2010, 12:18 AM
Re: An RCA 140 - by TA Forbes - 12-09-2010, 09:07 PM
Re: An RCA 140 - by Doug Houston - 01-01-2011, 08:44 PM
Re: An RCA 140 - by theboyzz - 01-29-2011, 12:14 AM
Eico 232 VTVM Schematic
There are currently 8493 online users. [Complete List]
» 2 Member(s) | 8491 Guest(s)
