Stromberg Carlson model 60
Hi Eric. What I ended up using for testing was an H-7 Its listed as 3275 ohms( DC resistance )on the speaker spread sheet, but mine was reading 3100 ohms. It was used in Philco 14LZX, 15X, 23X, and 91X.
I also had the companion speaker to the H-7 -the K-12, 8 inch - which also is listed as 3275 ohms.
Note; it does not have an output transformer> so I used a universal ot a 125D I think, and installed it in the cabinet. It plays fine. But I don't use it that much. Maybe once a month.
So tell the truth not sure what the exact field coil DC resistance should be. Used the K-12 as it was, with no added resistor.
I was finally able to find a 10 inch Stromberg speaker out of a model 65 that I plan to replace the Philco speaker with. It has a field coil DC resistance of 1060.
Stromberg Carlson model 60 - by KCMike - 04-02-2017, 07:05 PM
RE: Stromberg Carlson model 60 - by Arran - 04-03-2017, 04:05 AM
RE: Stromberg Carlson model 60 - by KCMike - 04-03-2017, 01:40 PM
RE: Stromberg Carlson model 60 - by Radioroslyn - 04-04-2017, 06:03 AM
RE: Stromberg Carlson model 60 - by Arran - 04-04-2017, 10:47 PM
RE: Stromberg Carlson model 60 - by KCMike - 04-05-2017, 05:11 PM
RE: Stromberg Carlson model 60 - by KCMike - 04-08-2017, 01:15 PM
RE: Stromberg Carlson model 60 - by Joe Rossi - 04-09-2017, 08:46 PM
RE: Stromberg Carlson model 60 - by KCMike - 04-10-2017, 09:58 AM
RE: Stromberg Carlson model 60 - by Eric - 06-06-2018, 09:20 AM
RE: Stromberg Carlson model 60 - by KCMike - 06-06-2018, 12:18 PM
RE: Stromberg Carlson model 60 - by Eric - 06-06-2018, 07:25 PM
RE: Stromberg Carlson model 60 - by Eric - 06-14-2018, 04:12 PM
RE: Stromberg Carlson model 60 - by KCMike - 06-14-2018, 04:37 PM
RE: Stromberg Carlson model 60 - by Eric - 06-14-2018, 05:53 PM
