Thoughts on finish
I don't think I have ever seen a mass produced tube radio finished with shellac. Given that they have survived in some cases for over eighty years, I would have to say that the lacquer finishes applied to the sets we work on have stood up pretty well. I see no reason to deviate from tradition.
Thoughts on finish - by oscartg - 06-06-2018, 11:54 AM
RE: Thoughts on finish - by Ron Ramirez - 06-06-2018, 12:35 PM
RE: Thoughts on finish - by oscartg - 06-06-2018, 12:40 PM
RE: Thoughts on finish - by John Bartley - 06-06-2018, 12:43 PM
RE: Thoughts on finish - by oscartg - 06-06-2018, 12:47 PM
RE: Thoughts on finish - by Ron Ramirez - 06-06-2018, 12:57 PM
RE: Thoughts on finish - by oscartg - 06-06-2018, 01:08 PM
RE: Thoughts on finish - by oscartg - 06-06-2018, 01:26 PM
RE: Thoughts on finish - by Ron Ramirez - 06-06-2018, 02:20 PM
RE: Thoughts on finish - by oscartg - 06-06-2018, 02:28 PM
RE: Thoughts on finish - by Ron Ramirez - 06-06-2018, 02:30 PM
RE: Thoughts on finish - by EdHolland - 06-06-2018, 04:01 PM
RE: Thoughts on finish - by Arran - 06-07-2018, 12:32 AM
RE: Thoughts on finish - by tbone - 06-07-2018, 06:20 AM
RE: Thoughts on finish - by John Bartley - 06-07-2018, 06:41 AM
RE: Thoughts on finish - by tbone - 06-07-2018, 06:47 AM
RE: Thoughts on finish - by EdHolland - 06-07-2018, 12:58 PM
RE: Thoughts on finish - by rdnzl - 06-07-2018, 01:21 PM
RE: Thoughts on finish - by Nathan Slingerland - 06-07-2018, 01:28 PM
RE: Thoughts on finish - by Phlogiston - 06-07-2018, 04:23 PM
RE: Thoughts on finish - by Arran - 06-07-2018, 10:00 PM
RE: Thoughts on finish - by oscartg - 06-12-2018, 11:12 AM
RE: Thoughts on finish - by Phlogiston - 06-12-2018, 02:53 PM
Eico 232 VTVM Schematic
There are currently 9301 online users. [Complete List]
» 2 Member(s) | 9299 Guest(s)
