Tropic 53-960 restoration
Just did that experiment with the oven.
I have just fnished baking some puff pastry and put the cap in. After 10 minutes...no, it won't come out. Something is oozing out of the cap but the glue won't melt.
Tropic 53-960 restoration - by morzh - 05-26-2018, 05:12 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 05-26-2018, 07:04 PM
RE: Tropic 53-960 restoration - by KCMike - 05-26-2018, 08:01 PM
RE: Tropic 53-960 restoration - by morzh - 05-26-2018, 08:09 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 05-26-2018, 09:28 PM
RE: Tropic 53-960 restoration - by morzh - 05-27-2018, 09:15 PM
RE: Tropic 53-960 restoration - by morzh - 05-27-2018, 09:41 PM
RE: Tropic 53-960 restoration - by Arran - 05-29-2018, 03:45 AM
RE: Tropic 53-960 restoration - by morzh - 05-29-2018, 08:01 AM
RE: Tropic 53-960 restoration - by morzh - 06-03-2018, 06:55 PM
RE: Tropic 53-960 restoration - by morzh - 06-05-2018, 10:39 PM
RE: Tropic 53-960 restoration - by Arran - 06-06-2018, 12:16 AM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-06-2018, 06:05 AM
RE: Tropic 53-960 restoration - by morzh - 06-06-2018, 07:18 PM
RE: Tropic 53-960 restoration - by morzh - 06-06-2018, 07:58 PM
RE: Tropic 53-960 restoration - by morzh - 06-06-2018, 08:41 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-06-2018, 09:12 PM
RE: Tropic 53-960 restoration - by morzh - 06-06-2018, 09:49 PM
RE: Tropic 53-960 restoration - by Arran - 06-07-2018, 05:25 AM
RE: Tropic 53-960 restoration - by morzh - 06-07-2018, 09:07 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-07-2018, 10:00 PM
RE: Tropic 53-960 restoration - by morzh - 06-08-2018, 06:30 PM
RE: Tropic 53-960 restoration - by morzh - 06-14-2018, 10:47 PM
RE: Tropic 53-960 restoration - by Arran - 06-15-2018, 04:06 AM
RE: Tropic 53-960 restoration - by morzh - 06-15-2018, 09:27 AM
RE: Tropic 53-960 restoration - by Arran - 06-16-2018, 03:28 AM
RE: Tropic 53-960 restoration - by morzh - 06-16-2018, 07:49 PM
RE: Tropic 53-960 restoration - by morzh - 06-17-2018, 05:52 PM
RE: Tropic 53-960 restoration - by KCMike - 06-17-2018, 07:13 PM
RE: Tropic 53-960 restoration - by morzh - 06-17-2018, 07:48 PM
RE: Tropic 53-960 restoration - by morzh - 06-22-2018, 07:47 PM
RE: Tropic 53-960 restoration - by morzh - 06-23-2018, 10:35 AM
RE: Tropic 53-960 restoration - by morzh - 06-23-2018, 01:48 PM
RE: Tropic 53-960 restoration - by sam - 06-23-2018, 02:29 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-23-2018, 03:14 PM
RE: Tropic 53-960 restoration - by morzh - 06-23-2018, 03:29 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-23-2018, 03:44 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-23-2018, 03:47 PM
RE: Tropic 53-960 restoration - by morzh - 06-23-2018, 04:08 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-23-2018, 04:24 PM
RE: Tropic 53-960 restoration - by morzh - 06-23-2018, 04:42 PM
RE: Tropic 53-960 restoration - by morzh - 06-23-2018, 08:27 PM
RE: Tropic 53-960 restoration - by morzh - 06-24-2018, 05:58 PM
RE: Tropic 53-960 restoration - by KCMike - 06-24-2018, 07:25 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-24-2018, 07:51 PM
RE: Tropic 53-960 restoration - by KCMike - 06-24-2018, 08:09 PM
RE: Tropic 53-960 restoration - by morzh - 06-24-2018, 08:19 PM
RE: Tropic 53-960 restoration - by Ron Ramirez - 06-24-2018, 09:41 PM
RE: Tropic 53-960 restoration - by morzh - 06-24-2018, 10:36 PM
RE: Tropic 53-960 restoration - by morzh - 06-27-2018, 09:00 PM
RE: Tropic 53-960 restoration - by morzh - 06-28-2018, 10:24 PM
RE: Tropic 53-960 restoration - by WyTex - 06-29-2018, 08:47 AM
RE: Tropic 53-960 restoration - by morzh - 06-29-2018, 09:06 AM
RE: Tropic 53-960 restoration - by WyTex - 06-29-2018, 09:35 AM
RE: Tropic 53-960 restoration - by morzh - 06-29-2018, 12:12 PM
RE: Tropic 53-960 restoration - by morzh - 06-29-2018, 09:30 PM
Users browsing this thread: 16 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4811 online users. [Complete List]
» 2 Member(s) | 4809 Guest(s)
