Output Transformer for Model 41-300
According to the 1946 Philco parts catalog, both use the same output transformer. Make sure your 39-55 transformer is good before you go to the trouble of switching it from one chassis to the other! The audio output transformers in Philco sets that are mounted under the chassis are all prone to failure, much more so than the older ones (1938 and older) which were mounted on the speaker.
Output Transformer for Model 41-300 - by hyounce - 08-31-2010, 11:48 PM
Re: Output Transformer for Model 41-300 - by Ron Ramirez - 09-01-2010, 10:38 AM
There are currently 2566 online users. [Complete List]
» 2 Member(s) | 2564 Guest(s)
