Model 87 Dial string
Hi Tom,
Have a look at this earlier thread:
http://philcoradio.com/phorum/showthread.php?tid=18043
Model 87 Dial string - by tom7391196 - 06-09-2018, 04:31 PM
RE: Model 87 Dial string - by Nathan Slingerland - 06-09-2018, 04:54 PM
RE: Model 87 Dial string - by mikethedruid - 06-09-2018, 05:27 PM
RE: Model 87 Dial string - by Radioroslyn - 06-09-2018, 06:24 PM
RE: Model 87 Dial string - by Chris h - 06-12-2018, 08:17 AM
RE: Model 87 Dial string - by Radioroslyn - 06-12-2018, 09:22 AM
RE: Model 87 Dial string - by Kestas - 06-18-2018, 01:30 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4881 online users. [Complete List]
» 1 Member(s) | 4880 Guest(s)
