Static in volume control?
The control probably needs to be cleaned or replaced. I would suggest you use DeOxit or tuner cleaner. You have to get the stuff into the control for it to work. Then it needs to be rotated back and forth a few times with the power off. Let everything dry out for an hour or two before powering up again.
Static in volume control? - by marcapra - 06-28-2010, 12:25 AM
Re: Static in volume control? - by codefox1 - 06-28-2010, 09:52 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
