Philco vtvom 7001 line caps?
While checking out the vtvom I found it had 62v ac. between the chassis and earth ground. Did not matter which way it was plugged in.
It has 2 -.25 line bypass caps from the primary of transformer to chassis.
 Put an 1000 ohm resistor between the chassis and earth ground and measured across it and have 12 volts. So I cut the ground side of the .25 caps and jumpered in 2-.01 Y-type disc safety caps. It now reads 51v ac chassis to earth ground and.05v ac across the resistor.
 Two questions I need help with.
 Is the 51v with the new caps a phantom voltage?
Can I use the .01 safety caps to replace the .25 caps or should I order the larger value safety caps?
 Any help greatly appreciated.
Philco vtvom 7001 line caps? - by KCMike - 06-10-2018, 10:59 AM
RE: Philco vtvom 7001 line caps? - by Chas - 06-12-2018, 08:45 AM
RE: Philco vtvom 7001 line caps? - by KCMike - 06-12-2018, 08:28 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9482 online users. [Complete List]
» 2 Member(s) | 9480 Guest(s)
