Line cord 42-1008
A possible solution for those who want to replace a power cord through one of these fanged holes is to buy a roll of the uncured rubber electrical tape from any good hardware store. Wrap some around the cord where it will pass through the hole. make it thick enough in diameter so that it needs to be squashed a bit to fit through. It will cure into solid rubber after a while, it will protect the cord, and act just like a "molded on" strain relief.
Line cord 42-1008 - by soldersucker - 05-29-2018, 04:10 PM
RE: Line cord 42-1008 - by NostalgiaRadioTime - 05-29-2018, 06:30 PM
RE: Line cord 42-1008 - by Ron Ramirez - 05-29-2018, 07:08 PM
RE: Line cord 42-1008 - by Patrick - 05-29-2018, 09:05 PM
RE: Line cord 42-1008 - by NostalgiaRadioTime - 05-29-2018, 10:47 PM
RE: Line cord 42-1008 - by Arran - 05-30-2018, 03:19 AM
RE: Line cord 42-1008 - by Ron Ramirez - 05-30-2018, 06:06 AM
RE: Line cord 42-1008 - by Ed Locker - 05-30-2018, 09:14 AM
RE: Line cord 42-1008 - by soldersucker - 06-09-2018, 09:20 PM
RE: Line cord 42-1008 - by Arran - 06-09-2018, 10:07 PM
RE: Line cord 42-1008 - by soldersucker - 06-10-2018, 07:55 AM
RE: Line cord 42-1008 - by soldersucker - 06-10-2018, 08:50 AM
RE: Line cord 42-1008 - by mikethedruid - 06-10-2018, 03:49 PM
RE: Line cord 42-1008 - by soldersucker - 06-10-2018, 08:09 PM
91H Code 126 Restore
There are currently 4886 online users. [Complete List]
» 2 Member(s) | 4884 Guest(s)
