Philco 42-1012 turntable questions
A friend of my is restoring Philco 42-1012 console. He was looking for some information and I hope you guys can help him:
- what is the diameter of the turntable motor shaft?
- what is the diameter of the rubbered roller, which rotates the disc?
Thank you in advance for your help!
Leonid
Philco 42-1012 turntable questions - by Ragazzo - 06-30-2010, 11:25 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6367 online users. [Complete List]
» 1 Member(s) | 6366 Guest(s)
