1936 Clinton 216 radio - lots of questions!
Thanks, Terry.  I'll check this evening after dinner.  Anyone have any input regarding "Plant A" radios?  I've found little information, but it went from junk sets to cutting edge technology!  Quite the secretive company.  Take care, Gary
RE: 1936 Clinton 216 radio - lots of questions! - by GarySP - 06-11-2018, 05:54 PM
