Scored a nice Dewald Pierce Airo 632
Murf;
  I think I would keep the Pierce Airo (Dewald) and sell the brand Z, it's probably not worth as much but they are a lot less common then the Brand Z sets. One note of caution, the DC may mean that it's a 110 volt DC mains radio, not a battery set, which makes it somewhat rare, but it also makes them a pain if you want to try powering it up. Don't worry, you probably did not ruin anything powering it up an AC, but all it would do is hum since it has no rectifier tube, nor filters if it is a DC mains set.
Scored a nice Dewald Pierce Airo 632 - by murf - 06-11-2018, 10:27 PM
RE: Scored a nice Dewald Pierce Auto DC-632 - by Arran - 06-11-2018, 10:35 PM
