Scored a nice Dewald Pierce Airo 632
Murf;
  Here is the schematic, at least a Nostalgia Air version of one, it seems to use a set of battery type tubes, many other DC mains sets used AC tubes and a big dropping resistor, such as the Philco models. It would not be too difficult to power up this set, but the performance would be something akin to a farm battery radio from the era, it's a TRF set in case you were wondering, sort of like a Philco 20.
http://www.nostalgiaair.org/pagesbymodel...043827.pdf
Scored a nice Dewald Pierce Airo 632 - by murf - 06-11-2018, 10:27 PM
RE: Scored a nice Dewald Pierce Auto DC-632 - by Arran - 06-12-2018, 02:02 AM
There are currently 9633 online users. [Complete List]
» 1 Member(s) | 9632 Guest(s)
