RCA 110K2 Unexpected project
Threads: 54
Ed;
Does the speaker cable use cloth or rubber/gutta percha covered wire? The RCA A-30 I'm working on used cloth covered, and I think it's still good and flexible, but the speaker is in the cabinet which is tucked in the corner in another room, I've been using the speaker out of an RCA A-22 table set for testing, the wires in the antenna cable are bad of course.
RE: RCA 110K2 Unexpected project - by Arran - 06-12-2018, 03:27 AM
Users browsing this thread: 28 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9948 online users. [Complete List] » 3 Member(s) | 9945 Guest(s)
