1936 Clinton 216 radio - lots of questions!
Hello Arran,  I was able to get the schematic for the set from Radiomuseum.  As far as the cabinet is concerned, it was in direct water contact and most of the veneer separated and curled away.  What's left has some pretty hefty warpage.  Take care, Gary
RE: 1936 Clinton 216 radio - lots of questions! - by GarySP - 06-12-2018, 08:48 AM
There are currently 9696 online users. [Complete List]
» 2 Member(s) | 9694 Guest(s)
