*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
Threads: 3
City: Chesapeake VA
As Terry stated schematic is wrong, radio must be correct or the 150ma 50L6(s) would have excessive heater voltage and other tubes with 300ma heaters just barely lighting. The late version shows 50A5 wired correctly.
Tube pin count is always clockwise from locater key(or space for miniature tubes).
There are two unused pins on 25Z6
25Z6 [Image: http://www.nj7p.org/Tubes/SQL/Bases/7Q.png]
Tom
RE: Minerva Tropic Master model w117 "EARLY" - by 35Z5 - 06-12-2018, 04:14 PM
Users browsing this thread: 38 Guest(s)
Dan;
I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM |
Milkjug plastic?
Whatever is chosen for the spider, the material must be compatible with popular adhesives...
Th...Chas — 05:05 PM |
Mike;
I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM |
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM |
Yes, Mark belongs to the same Michigan Antique Radio Club that I do. I suspect that the oscillator coil is in need of a ...Radios1340 — 03:10 PM |
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM |
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM |
My back hurts already, you could build a house with all the wood. PaulPaul Philco322 — 02:49 PM |
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
There are currently 7433 online users. [Complete List] » 2 Member(s) | 7431 Guest(s)
