Need help ID'ing console ('29 Model 65?)
Great! The underside is very clean and appears untouched. You're in luck! Icon_smile
The four brown phenolic tubes with solder lugs on them are resistor/cap combo's: parts 5, 6, 10 and 27. They can be re-stuffed and remain original looking.
The big wire-wound ceramic power resistor is the "BC" resistor, part 24. It is shown in two sections on the schematic; one part is the filament winding center-tap for the 45 tubes and the other is in the power supply output resistor network.
[No subject] - by Chuck Schwark - 01-31-2006, 12:21 AM
[No subject] - by noiseguy - 01-31-2006, 09:55 AM
[No subject] - by Ron Ramirez - 01-31-2006, 09:59 AM
[No subject] - by Chuck Schwark - 01-31-2006, 10:03 AM
[No subject] - by Ron Ramirez - 01-31-2006, 01:06 PM
[No subject] - by rjm - 01-31-2006, 03:33 PM
[No subject] - by noiseguy - 02-01-2006, 11:40 PM
[No subject] - by Chuck Schwark - 02-01-2006, 11:52 PM
[No subject] - by noiseguy - 02-02-2006, 05:09 PM
[No subject] - by Chuck Schwark - 02-02-2006, 05:44 PM
[No subject] - by noiseguy - 02-17-2006, 01:09 PM
[No subject] - by rjm - 02-17-2006, 02:15 PM
[No subject] - by noiseguy - 03-27-2006, 12:45 AM
[No subject] - by rjm - 03-27-2006, 02:01 AM
[No subject] - by noiseguy - 03-27-2006, 09:12 AM
[No subject] - by noiseguy - 03-27-2006, 09:34 AM
Eico 232 VTVM Schematic
There are currently 8913 online users. [Complete List]
» 1 Member(s) | 8912 Guest(s)
