What am I looking for 37-620CS
Tnx Russ,
Here's a sanded strip I removed from the top. The cabinet is in the shed under some stuff, thinking of working on it in the fall and want to get the veneer before I start on it. Now I just have to find the chassis and spkr  [Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
What am I looking for 37-620CS - by Radioroslyn - 06-13-2018, 07:23 PM
RE: What am I looking for 37-620CS - by Radioroslyn - 06-14-2018, 01:00 PM
RE: What am I looking for 37-620CS - by rfeenstra - 06-14-2018, 05:04 PM
RE: What am I looking for 37-620CS - by Arran - 06-18-2018, 04:24 AM
RE: What am I looking for 37-620CS - by Arran - 06-24-2018, 04:02 AM
Philco 91 Tuning Condenser
There are currently 7535 online users. [Complete List]
» 2 Member(s) | 7533 Guest(s)
