Scored a nice Dewald Pierce Airo 632
Murf, the AC version is model AC-524, has 5 tubes, and the transformer is under the chassis:
http://www.nostalgiaair.org/pagesbymodel...043822.pdf
Just pull the chassis or look at the tube numbers to be sure, but I think you have the AC version.  It looks pretty decent, but that grille cloth has got to go Icon_e_wink
Scored a nice Dewald Pierce Airo 632 - by murf - 06-11-2018, 10:27 PM
RE: Scored a nice Dewald Pierce Airo 632 - by Eliot Ness - 06-14-2018, 07:23 PM
There are currently 8159 online users. [Complete List]
» 1 Member(s) | 8158 Guest(s)
