Question on my Philco 41-295 lamp
Has anyone thought about melting some wax, mix in soon brown coloring, put a strip on one end then dip the yellow caps in the wax. That would calm down the yellow caps don't you think.
Michael
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
Question on my Philco 41-295 lamp - by nortonz - 05-15-2018, 03:32 PM
RE: Question on my Philco 41-295 lamp - by Arran - 06-12-2018, 02:45 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-13-2018, 12:31 AM
RE: Question on my Philco 41-295 lamp - by Arran - 06-14-2018, 03:15 AM
RE: Question on my Philco 41-295 lamp - by nortonz - 06-15-2018, 11:53 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4891 online users. [Complete List]
» 2 Member(s) | 4889 Guest(s)
