Replacing a missing speaker
Replaced the all the electrolytic's and the safety caps and most of the other caps except those in the potted can. tested the tubes, the power transformer test good (worried about that one)!
Found a speaker to use as a test but am unsure of the hook up.
The output Xformer would go across # 1&6 large pins ?
and the FC would go across # 3 & 5?
Looking from the connection side of the socket going cw with the first large pin being # 1.
Do I have it right?
Replacing a missing speaker - by Eric - 06-08-2018, 08:56 AM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 10:02 AM
RE: Replacing a missing speaker - by Eric - 06-08-2018, 02:00 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 02:56 PM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 03:03 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 03:21 PM
RE: Replacing a missing speaker - by Arran - 06-09-2018, 02:41 AM
RE: Replacing a missing speaker - by Chas - 06-09-2018, 10:03 AM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 02:40 PM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 03:10 PM
RE: Replacing a missing speaker - by Arran - 06-11-2018, 02:24 AM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 05:50 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 06:20 PM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 07:45 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 07:58 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 11:52 AM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 01:23 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-18-2018, 01:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 03:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 04:00 PM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 05:34 PM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 07:58 AM
RE: Replacing a missing speaker - by KCMike - 06-19-2018, 08:47 AM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 09:50 AM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 01:02 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-28-2018, 04:44 PM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 10:07 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-29-2018, 03:12 PM
RE: Replacing a missing speaker - by Eric - 06-30-2018, 10:14 AM
RE: Replacing a missing speaker - by Radioroslyn - 06-30-2018, 11:47 AM
RE: Replacing a missing speaker - by Eric - 07-02-2018, 03:44 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 02:56 PM
RE: Replacing a missing speaker - by Radioroslyn - 07-10-2018, 03:19 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 05:06 PM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 09:54 AM
RE: Replacing a missing speaker - by KCMike - 07-12-2018, 10:11 AM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 04:18 PM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 09:35 AM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 10:51 AM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 05:01 PM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 07:03 PM
There are currently 8901 online users. [Complete List]
» 2 Member(s) | 8899 Guest(s)
