Zenith 9S232 sensitivity control
https://www.youtube.com/watch?v=f5e-2KmOnWA
So ah where is switch #8 it's seems to be invisible??
RE: Zenith 9S232 sensitivity control - by tbone - 06-18-2018, 12:05 PM
RE: Zenith 9S232 sensitivity control - by Radioroslyn - 06-18-2018, 01:52 PM
RE: Zenith 9S232 sensitivity control - by tbone - 06-18-2018, 09:18 PM
RE: Zenith 9S232 sensitivity control - by morzh - 06-18-2018, 10:17 PM
RE: Zenith 9S232 sensitivity control - by tbone - 06-19-2018, 05:01 AM
RE: Zenith 9S232 sensitivity control - by tbone - 06-19-2018, 08:14 PM
RE: Zenith 9S232 sensitivity control - by Arran - 06-20-2018, 02:57 AM
There are currently 9409 online users. [Complete List]
» 1 Member(s) | 9408 Guest(s)
