91D restoration
We really need OEM controls decal data, sizes, positioning, etc for our 91D just starting a cautious restoration now.
Existing decals all rubbed of decades ago around the knobs except a little of the centered Philco logo. Cabinet seems real good as is - but we are amateurs.
Also - ANY suggestions on cabinet cleaning, etc. are welcomed.
Chassis (noted as Type 18, Code 121 w/ a single external phono and switch connection located on the rear back side of the cabinet) and the radio's speaker / board were just dropped of at a local Twin Cities antique radio shop for repairs / refurbishment, etc.
Thanks Icon_biggrin
chbpe
91D restoration - by Guest - 07-02-2010, 04:37 PM
Re: 91D restoration - by Chuck Schwark - 07-03-2010, 01:27 PM
Re: 91D restoration - by Ron Ramirez - 07-04-2010, 08:38 AM
Re: 91D restoration - by Guest - 07-04-2010, 10:50 AM
Re: 91D restoration - by Ron Ramirez - 07-04-2010, 12:30 PM
Re: 91D restoration - by Guest - 07-04-2010, 01:23 PM
Re: 91D restoration - by Ron Ramirez - 07-04-2010, 01:45 PM
Re: 91D restoration - by Guest - 07-05-2010, 03:34 PM
Re: 91D restoration - by Ron Ramirez - 07-05-2010, 03:38 PM
Re: 91D restoration - by Guest - 07-11-2010, 02:59 PM
Re: 91D restoration - by Ron Ramirez - 07-11-2010, 04:46 PM
Re: 18D restoration - by Guest - 07-11-2010, 08:39 PM
Re: 91D restoration - by Ron Ramirez - 07-11-2010, 09:35 PM
Re: 18D restoration - by Guest - 07-12-2010, 02:14 PM
Re: 18D restoration - by Guest - 07-13-2010, 07:53 PM
Re: 91D restoration - by Ron Ramirez - 07-13-2010, 08:25 PM
Re: 91D restoration - by TexMac - 07-18-2010, 02:31 PM
Re: 18D restoration - by Guest - 07-20-2010, 10:49 AM
There are currently 9661 online users. [Complete List]
» 1 Member(s) | 9660 Guest(s)
