What did I get myself into?
Hi Brian and welcome,
Well it depends. If you mean expense wise would think abt $50 in parts barring anything major.
If you mean technically yes there is a bit of a learning curve but if you have the motivation and some skills like soldering wiring and such that's a big +. Don't really have broach the deep technical stuff unless you'd like to.
Things like small hand tools, wire cutters, small drill, dremel tool, nn pliers, nut drivers, volt ohm meter. Signal generator is nice to have too.
As mentioned before a lot help here self include so if you have any question we're happy to entertain them.
What did I get myself into? - by brianbbs67 - 06-17-2018, 10:39 PM
RE: What did I get myself into? - by brianbbs67 - 06-17-2018, 11:09 PM
RE: What did I get myself into? - by brianbbs67 - 06-17-2018, 11:17 PM
RE: What did I get myself into? - by brianbbs67 - 06-17-2018, 11:20 PM
RE: What did I get myself into? - by brianbbs67 - 06-18-2018, 12:22 AM
RE: What did I get myself into? - by mikethedruid - 06-18-2018, 01:45 AM
RE: What did I get myself into? - by OldRestorer - 06-18-2018, 02:36 PM
RE: What did I get myself into? - by mikethedruid - 06-18-2018, 04:03 PM
RE: What did I get myself into? - by Radioroslyn - 06-18-2018, 06:23 PM
RE: What did I get myself into? - by brianbbs67 - 06-18-2018, 09:48 PM
RE: What did I get myself into? - by Ron Ramirez - 06-18-2018, 09:52 PM
RE: What did I get myself into? - by brianbbs67 - 06-18-2018, 10:47 PM
RE: What did I get myself into? - by brianbbs67 - 06-18-2018, 10:50 PM
RE: What did I get myself into? - by Radioroslyn - 06-19-2018, 07:24 AM
RE: What did I get myself into? - by brianbbs67 - 06-19-2018, 11:01 PM
RE: What did I get myself into? - by Radioroslyn - 06-20-2018, 11:52 AM
RE: What did I get myself into? - by Brad Winder - 06-20-2018, 10:27 PM
RE: What did I get myself into? - by mikethedruid - 06-20-2018, 11:00 PM
RE: What did I get myself into? - by brianbbs67 - 06-20-2018, 11:07 PM
RE: What did I get myself into? - by brianbbs67 - 06-21-2018, 12:58 AM
RE: What did I get myself into? - by Brad Winder - 06-21-2018, 09:31 AM
RE: What did I get myself into? - by Radioroslyn - 06-21-2018, 11:50 AM
RE: What did I get myself into? - by brianbbs67 - 06-21-2018, 09:13 PM
RE: What did I get myself into? - by brianbbs67 - 06-21-2018, 10:32 PM
RE: What did I get myself into? - by Radioroslyn - 06-22-2018, 05:44 PM
RE: What did I get myself into? - by brianbbs67 - 06-23-2018, 12:50 AM
RE: What did I get myself into? - by brianbbs67 - 06-26-2018, 11:26 AM
RE: What did I get myself into? - by Radioroslyn - 06-26-2018, 12:38 PM
RE: What did I get myself into? - by brianbbs67 - 06-26-2018, 07:54 PM
RE: What did I get myself into? - by brianbbs67 - 06-26-2018, 10:19 PM
RE: What did I get myself into? - by brianbbs67 - 06-26-2018, 10:20 PM
RE: What did I get myself into? - by Radioroslyn - 06-26-2018, 10:26 PM
RE: What did I get myself into? - by brianbbs67 - 06-27-2018, 12:36 AM
RE: What did I get myself into? - by brianbbs67 - 06-28-2018, 09:38 PM
RE: What did I get myself into? - by mikethedruid - 06-28-2018, 10:17 PM
RE: What did I get myself into? - by Radioroslyn - 06-28-2018, 11:38 PM
RE: What did I get myself into? - by brianbbs67 - 06-29-2018, 02:15 AM
RE: What did I get myself into? - by brianbbs67 - 06-29-2018, 02:16 AM
RE: What did I get myself into? - by brianbbs67 - 07-01-2018, 01:22 AM
RE: What did I get myself into? - by brianbbs67 - 07-01-2018, 01:24 AM
RE: What did I get myself into? - by Steve Davis - 07-01-2018, 08:28 AM
RE: What did I get myself into? - by brianbbs67 - 07-01-2018, 09:56 PM
RE: What did I get myself into? - by Steve Davis - 07-01-2018, 11:07 PM
RE: What did I get myself into? - by brianbbs67 - 07-02-2018, 12:49 AM
RE: What did I get myself into? - by brianbbs67 - 07-02-2018, 11:01 PM
RE: What did I get myself into? - by mikethedruid - 07-03-2018, 12:55 AM
RE: What did I get myself into? - by brianbbs67 - 07-05-2018, 12:22 AM
There are currently 10104 online users. [Complete List]
» 2 Member(s) | 10102 Guest(s)
