Zenith 9S232 sensitivity control
The switch is that power switch knob on the right saying Local/long distance. In LD position it shunts that resistor.
RE: Zenith 9S232 sensitivity control - by tbone - 06-18-2018, 12:05 PM
RE: Zenith 9S232 sensitivity control - by tbone - 06-18-2018, 09:18 PM
RE: Zenith 9S232 sensitivity control - by morzh - 06-18-2018, 10:17 PM
RE: Zenith 9S232 sensitivity control - by tbone - 06-19-2018, 05:01 AM
RE: Zenith 9S232 sensitivity control - by tbone - 06-19-2018, 08:14 PM
RE: Zenith 9S232 sensitivity control - by Arran - 06-20-2018, 02:57 AM
There are currently 9970 online users. [Complete List]
» 2 Member(s) | 9968 Guest(s)
