Started the restore on my Philco 40-180.
I HAD to replace both strips on my 40-180. Haven’t completed the job yet, hope to finish tomorrow and will post a picture of the completed cabinet. I used rosewood veneer to replace what few pieces of the original I had. Put some Clear Sanding Seal on the veneer after gluing it to the substrate. Looks pretty good to me. Will post picture soon.
RE: Started the restore on my Philco 40-180. - by Mjeansonne - 06-18-2018, 11:37 PM
Is this veneer zebrawood? - by nortonz - 06-18-2018, 01:33 AM
RE: Is this veneer zebrawood? - by Arran - 06-18-2018, 02:50 AM
