Zenith 9S232 sensitivity control
Thanks for the offer, Tony. It couldn't hurt having the original RF coil. Let me know if you find one that tests good on your junker chassis.
Will check out that mica, too. I want to check a few of the non dogbone resistors too again that I didn't replace. Sometimes those little 1/4 watt jobbers can be even further off than the big 1 watts.
RE: Zenith 9S232 sensitivity control - by tbone - 06-18-2018, 12:05 PM
RE: Zenith 9S232 sensitivity control - by tbone - 06-18-2018, 09:18 PM
RE: Zenith 9S232 sensitivity control - by morzh - 06-18-2018, 10:17 PM
RE: Zenith 9S232 sensitivity control - by tbone - 06-19-2018, 05:01 AM
RE: Zenith 9S232 sensitivity control - by NostalgiaRadioTime - 06-19-2018, 07:05 AM
RE: Zenith 9S232 sensitivity control - by tbone - 06-19-2018, 08:14 PM
RE: Zenith 9S232 sensitivity control - by Arran - 06-20-2018, 02:57 AM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2672 online users. [Complete List]
» 1 Member(s) | 2671 Guest(s)
