Replacing a missing speaker
Mike
Yes L 17, 18 are good, checked most of the coils and they are good.
unfortunately I have to leave it for a week going to KY to visit the grand kids.
I think I will give it a try with the one tube one of the things I didn't have is the jumper in place and to make sure the choke and FC are connected. Started tracing all the leads and marking them on the print to see what was changed. Seems like a lot of work for one tube.
Thanks for all the help
Eric
Replacing a missing speaker - by Eric - 06-08-2018, 08:56 AM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 10:02 AM
RE: Replacing a missing speaker - by Eric - 06-08-2018, 02:00 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 02:56 PM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 03:03 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 03:21 PM
RE: Replacing a missing speaker - by Arran - 06-09-2018, 02:41 AM
RE: Replacing a missing speaker - by Chas - 06-09-2018, 10:03 AM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 02:40 PM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 03:10 PM
RE: Replacing a missing speaker - by Arran - 06-11-2018, 02:24 AM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 05:50 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 06:20 PM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 07:45 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 07:58 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 11:52 AM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 01:23 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-18-2018, 01:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 03:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 04:00 PM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 05:34 PM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 07:58 AM
RE: Replacing a missing speaker - by KCMike - 06-19-2018, 08:47 AM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 09:50 AM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 01:02 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-28-2018, 04:44 PM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 10:07 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-29-2018, 03:12 PM
RE: Replacing a missing speaker - by Eric - 06-30-2018, 10:14 AM
RE: Replacing a missing speaker - by Radioroslyn - 06-30-2018, 11:47 AM
RE: Replacing a missing speaker - by Eric - 07-02-2018, 03:44 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 02:56 PM
RE: Replacing a missing speaker - by Radioroslyn - 07-10-2018, 03:19 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 05:06 PM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 09:54 AM
RE: Replacing a missing speaker - by KCMike - 07-12-2018, 10:11 AM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 04:18 PM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 09:35 AM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 10:51 AM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 05:01 PM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 07:03 PM
There are currently 9144 online users. [Complete List]
» 2 Member(s) | 9142 Guest(s)
