Started the restore on my Philco 40-180.
The cabinet is all ready to seal, just have to do something with that veneer, been looking at different types, trying to figure out what to use. The other problem I'd the original the grain goes on an angle, so to replace the whole strip would take a fairly large strip. I think I have decided to replace both strips, they are both in pretty bad shape.
Michael
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
RE: Started the restore on my Philco 40-180. - by nortonz - 06-19-2018, 02:27 PM
Is this veneer zebrawood? - by nortonz - 06-18-2018, 01:33 AM
RE: Is this veneer zebrawood? - by Arran - 06-18-2018, 02:50 AM
Eico 232 VTVM Schematic
There are currently 10086 online users. [Complete List]
» 1 Member(s) | 10085 Guest(s)
