Can I use the H-13 speaker?
Hi Ron, I checked, and it does have continuity. It's yours! Icon_biggrin
Can I use the H-13 speaker? - by jeremyfries - 07-01-2010, 07:46 PM
Re: Can I use the H-13 speaker? - by Steve Davis - 07-01-2010, 10:16 PM
Re: Can I use the H-13 speaker? - by jeremyfries - 07-01-2010, 11:52 PM
Re: Can I use the H-13 speaker? - by Ron Ramirez - 07-02-2010, 07:18 AM
Re: Can I use the H-13 speaker? - by jeremyfries - 07-02-2010, 05:55 PM
Re: Can I use the H-13 speaker? - by jeremyfries - 07-03-2010, 02:20 AM
Re: Can I use the H-13 speaker? - by Ron Ramirez - 07-03-2010, 06:23 AM
Re: Can I use the H-13 speaker? - by jeremyfries - 07-03-2010, 01:42 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6675 online users. [Complete List]
» 1 Member(s) | 6674 Guest(s)
