Model 86 Curiosity
Nathan
No, my hum was present all the time.
Speaking of neutralizing procedure: one of the tubes was a dud with open filament. This makes any adapter unnecessary.
In fact, old neutralizing procedures, as noted by Ron, called for a dud. I would add, preferably from the same manufacturer and the same time periode, to keep the similarity as close as possible. I had exactly that.
Model 86 Curiosity - by Nathan Slingerland - 06-18-2018, 01:00 AM
RE: Model 86 Curiosity - by Radioroslyn - 06-18-2018, 10:04 AM
RE: Model 86 Curiosity - by Nathan Slingerland - 06-18-2018, 10:41 AM
RE: Model 86 Curiosity - by Ron Ramirez - 06-18-2018, 09:49 PM
RE: Model 86 Curiosity - by morzh - 06-18-2018, 10:13 PM
RE: Model 86 Curiosity - by Nathan Slingerland - 06-19-2018, 12:41 AM
RE: Model 86 Curiosity - by morzh - 06-19-2018, 10:27 AM
RE: Model 86 Curiosity - by Nathan Slingerland - 06-19-2018, 11:51 PM
RE: Model 86 Curiosity - by Arran - 06-20-2018, 03:37 AM
RE: Model 86 Curiosity - by Nathan Slingerland - 06-20-2018, 11:37 AM
RE: Model 86 Curiosity - by morzh - 06-20-2018, 08:50 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5939 online users. [Complete List]
» 1 Member(s) | 5938 Guest(s)
