Ron's RCA T7-5 Electronic Rescue
#45
Tonight I polished the two electrolytic cans and reinstalled them on the chassis.
[Image: http://www.philcoradio.com/images/phorum...-5_046.jpg]
One of them is even hooked up now - see lower left of the photo below.
[Image: http://www.philcoradio.com/images/phorum...-5_047.jpg]
And Arran, I did try your suggestion on the "ears" of the nut holding the third electrolytic. After considerable hammering and bending, I was finally able to remove both nut, fiber washers, and electrolytic.
[Image: http://www.philcoradio.com/images/phorum...-5_048.jpg]
[Image: http://www.philcoradio.com/images/phorum...-5_049.jpg]
As you can see below, the threads at the bottom of the electrolytic can are badly mangled. I know that I caused some of this damage, but I believe the threads were already bad - which is why the nut refused to budge previously.
[Image: http://www.philcoradio.com/images/phorum...-5_050.jpg]
After considerable searching through my stash o'stuff, I managed to find one more stud mounting electrolytic can so I will be able to replace the original can. This is C35, 18 uF. I'll save this can for future use in a Philco with clamp mounting, where the damaged threads will not matter.
Hopefully I can manage to squeeze both 10 uF and 8.2 uF Solen Fast caps into the replacement can.
We shall see...
Ron's RCA T7-5 Electronic Rescue - by Ron Ramirez - 06-03-2018, 02:38 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-05-2018, 05:20 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-10-2018, 12:06 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-14-2018, 03:23 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-15-2018, 02:14 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-17-2018, 02:50 AM
RE: Ron's RCA T7-5 Electronic Rescue - by KCMike - 06-17-2018, 07:09 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-18-2018, 03:41 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Ron Ramirez - 06-20-2018, 09:47 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-21-2018, 05:08 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-22-2018, 04:27 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-24-2018, 03:42 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-04-2018, 04:17 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-06-2018, 12:21 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-11-2018, 06:16 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-13-2018, 10:57 PM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
