Delco 1212
Been listening to this quite a bit lately, a pretty good player and versatile, has tone control, RCA jack for phono, and a SW band.
Kind of an oddball like the cat in the last frame. Probably one of the last built before War Production took over. Has a style like they were not sure to build it big or small, case is good size with a lot of extra room inside, speaker off to side not dropped in front like a lot of post war sets, an odd duck.
My only Delco, only cat.
https://www.flickr.com/photos/92577012@N...8264245495
Finish is original. Just a bit of Howards Feed n Wax.
Delco 1212 - by Paul Philco322 - 06-22-2018, 12:22 PM
RE: Delco 1212 - by Brad Winder - 06-26-2018, 09:30 AM
RE: Delco 1212 - by Paul Philco322 - 06-26-2018, 12:03 PM
RE: Delco 1212 - by mikethedruid - 06-26-2018, 02:57 PM
RE: Delco 1212 - by Paul Philco322 - 06-26-2018, 08:23 PM
