Ron's RCA T7-5 Electronic Rescue
#56
I have removed the dial scale, the same way that Greg removed his - by turning the tuning condenser about halfway open, removing the four push pins that held the scale in place, and then carefully slipping it off the pointer.
Greg, how did you fasten your new dial scale to your T7-5? All four of the push pins that held my dial scale in place were rusted, and all four broke when I removed them.
I've hit the pointer with more PB Blaster where it is fastened to the tuning condenser shaft. With the dial scale out of the way, it is now easier to get PB Blaster into the point where pointer meets tuning condenser shaft.
I also removed and disassembled the ball bearing tuning assembly. It is made very much like Philco radios with two-speed tuning, and came apart the same way. It is soaking in naptha now to degrease everything. I have the knobs soaking in Evapo-Rust as the metal springs inside the knobs are badly rusted.
I attempted to rebuild the little top hat 6H6 tube and install two 1N34A diodes. Everything went well until I discovered that the top of the tube no longer fits properly onto the base. Icon_sad I could have sworn that there would be enough room for the diodes inside there...
Ron's RCA T7-5 Electronic Rescue - by Ron Ramirez - 06-03-2018, 02:38 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-05-2018, 05:20 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-10-2018, 12:06 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-14-2018, 03:23 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-15-2018, 02:14 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-17-2018, 02:50 AM
RE: Ron's RCA T7-5 Electronic Rescue - by KCMike - 06-17-2018, 07:09 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-18-2018, 03:41 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-21-2018, 05:08 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-22-2018, 04:27 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Ron Ramirez - 06-23-2018, 04:58 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 06-24-2018, 03:42 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-04-2018, 04:17 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-06-2018, 12:21 AM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-11-2018, 06:16 PM
RE: Ron's RCA T7-5 Electronic Rescue - by Arran - 07-13-2018, 10:57 PM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
