Model 96 - I need some advise/opinions
Give the wood work a real good detail cleaning with some sort of finish cleaner before putting something like wax or Howards on it. Use toothbrushes, Q tips etc. and wipe the whole thing well so you do not seal in any crud with the treatment you give it. After cleaning before treatment, you might also elect to use a stain touchup pen of the proper color to darken any light scratches. Wipe off any excess.
Model 96 - I need some advise/opinions - by Guest - 06-28-2010, 01:44 PM
Re: Model 96 - I need some advise/opinions - by tom2 - 07-04-2010, 07:48 PM
There are currently 8517 online users. [Complete List]
» 1 Member(s) | 8516 Guest(s)
