Delco/RCA same chassis
How is the 28X working out for you with the elliptical speaker? I have a 28X5 it is a good sounding set.
Delco/RCA same chassis - by lasurveyor - 06-04-2018, 11:52 AM
RE: Delco/RCA same chassis - by Paul Philco322 - 06-25-2018, 08:45 PM
RE: Delco/RCA same chassis - by Brad Winder - 06-26-2018, 12:08 AM
RE: Delco/RCA same chassis - by Arran - 06-26-2018, 04:33 AM
RE: Delco/RCA same chassis - by Paul Philco322 - 06-26-2018, 08:46 AM
RE: Delco/RCA same chassis - by lasurveyor - 06-26-2018, 11:01 AM
RE: Delco/RCA same chassis - by Paul Philco322 - 06-26-2018, 11:57 AM
There are currently 10453 online users. [Complete List]
» 2 Member(s) | 10451 Guest(s)
