Model 90 Tube Shield
Hello Ron:
Thanks for your reply. Using your information, I found photos on ebay of several Model 90’s with both tube shields. Now I know what I’m looking for should I decide to purchase the radio. I'll try to attach the photos for reference.
I appreciate your time and assistance.
Allen
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Model 90 Tube Shield - by Allen in SB - 06-25-2010, 11:16 PM
Re: Model 90 Tube Shield - by Ron Ramirez - 07-04-2010, 08:30 AM
Re: Model 90 Tube Shield - by Allen in SB - 07-06-2010, 11:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
