  • 1 Vote(s) - 4 Average
*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
11v on the 6sq7 is a problem. Measure the resistance from p6 to the chassis should see a high resistance. Perhaps 50K or better. A wrong value resistor on pin 6 or + voltage on the grid of the 6SQ7 could cause this circumstance. Voltage on the 6SC7 are good the one you noted is .95v vs 1.2 not a big deal.
RE: Minerva Tropic Master model w117 "EARLY" - by Radioroslyn - 06-26-2018, 07:51 PM
Users browsing this thread: 44 Guest(s)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7209 online users. [Complete List]
» 4 Member(s) | 7205 Guest(s)
AvatarAvatarAvatarAvatar
