*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
Threads: 3
City: Chesapeake VA
Scott, how many ohms per volt is that meter?? If it's like 20K ohms per volt, it's no doubt loading down the reading. If you were using one of those cheap Harbor Freight Chinese(you love so much) meters that was a megohm per volt, voltage would be higher. The 270K is fine, later radios used 330K or even as high as 470K for plate supply. Current is so miniscule a ¼ watt would be fine.
For noise, disconnect pins 4 & 5 on 6SQ7 to see if it stops(radio should be silent). If it does problem is ahead of audio amp in the RF/IF circuitry, may have a flakey IF transformer or cap inside. These aren't the transformers that are famed for noise problems, but I had a GE that acted exactly same and was the IF transformer.
Actually you can more or less tell with the heater test setup of 6SQ7 pictured. If you have additional leads, connecting pins other than 4 & 5 would be a valid test.
Tom
(This post was last modified: 06-27-2018, 10:03 AM by 35Z5.)
RE: Minerva Tropic Master model w117 "EARLY" - by 35Z5 - 06-27-2018, 09:58 AM
Users browsing this thread: 33 Guest(s)
Dan;
I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM |
Milkjug plastic?
Whatever is chosen for the spider, the material must be compatible with popular adhesives...
Th...Chas — 05:05 PM |
Mike;
I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM |
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM |
Yes, Mark belongs to the same Michigan Antique Radio Club that I do. I suspect that the oscillator coil is in need of a ...Radios1340 — 03:10 PM |
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM |
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM |
My back hurts already, you could build a house with all the wood. PaulPaul Philco322 — 02:49 PM |
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
There are currently 7287 online users. [Complete List] » 2 Member(s) | 7285 Guest(s)
