Farnsworth GK-669 . What is this device ?
I finished the repair of the radio chassis and the adjustment of the mechanism of the gramophone record player.
I took a short video with a demonstration of the work of the programmer with a gramophone changer.
Artist - Fausto Papetti, alto saxophone, jazz composition Washington square.
[Video: https://www.youtube.com/watch?v=RTQmFHCjLts]
RE: Farnsworth GK-669 . What is this device ? - by RadioSvit - 06-27-2018, 05:01 PM
There are currently 10390 online users. [Complete List]
» 1 Member(s) | 10389 Guest(s)
