Philco 52-542-1 totally dead
The reason I asked the question about the number of the dial lamp I have found some very creative work when folks did not have the correct bulb. One set had a appliance bulb installed at the back of the set but with a 15 watts bulb you could see the dial, even when the set was turned off, radio and night light combo.
Philco 52-542-1 totally dead - by Jeffbo1 - 06-26-2018, 10:36 AM
RE: Philco 52-542-1 totally dead - by Chas - 06-26-2018, 10:59 AM
RE: Philco 52-542-1 totally dead - by David - 06-26-2018, 02:06 PM
RE: Philco 52-542-1 totally dead - by morzh - 06-26-2018, 05:09 PM
RE: Philco 52-542-1 totally dead - by David - 06-26-2018, 06:01 PM
RE: Philco 52-542-1 totally dead - by 35Z5 - 06-27-2018, 10:06 AM
RE: Philco 52-542-1 totally dead - by David - 06-27-2018, 05:22 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7358 online users. [Complete List]
» 1 Member(s) | 7357 Guest(s)
