Replacing a missing speaker
Ok.
A couple of things stick out to me. Pin 4 of the 41 should read - 16vdc. Having +10vdc on it will cause the tube to draw excessive plate current. This maybe why pin 2 only has 112v. If it's a typo your output transformer is trashed, replace it.
The IF adjustments it doesn't really matter where the tuning dial is set. Inject a 370kc signal into the cap on the 6A7 and adjust the four trimmers inside the IF cans for max sound from the spkr w/the generator set @ minimum output. Note two of the four little screws have HV on them so insulate your tuning tool if it's not plastic.
It's not unusual for the grid 1 voltage to vary w/oscillator frequency (as you tune the dial). Typically it's abt -2 or 3 vdc so the .2 would indicate that the oscillator isn't working but since you have a few volts - it would seem to be ok. If you suspect it you can listen for it @ 370kc above the dial reading on another receiver.
Replacing a missing speaker - by Eric - 06-08-2018, 08:56 AM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 10:02 AM
RE: Replacing a missing speaker - by Eric - 06-08-2018, 02:00 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 02:56 PM
RE: Replacing a missing speaker - by KCMike - 06-08-2018, 03:03 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-08-2018, 03:21 PM
RE: Replacing a missing speaker - by Arran - 06-09-2018, 02:41 AM
RE: Replacing a missing speaker - by Chas - 06-09-2018, 10:03 AM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 02:40 PM
RE: Replacing a missing speaker - by Eric - 06-10-2018, 03:10 PM
RE: Replacing a missing speaker - by Arran - 06-11-2018, 02:24 AM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 05:50 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 06:20 PM
RE: Replacing a missing speaker - by Eric - 06-17-2018, 07:45 PM
RE: Replacing a missing speaker - by KCMike - 06-17-2018, 07:58 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 11:52 AM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 01:23 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-18-2018, 01:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 03:34 PM
RE: Replacing a missing speaker - by Eric - 06-18-2018, 04:00 PM
RE: Replacing a missing speaker - by KCMike - 06-18-2018, 05:34 PM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 07:58 AM
RE: Replacing a missing speaker - by KCMike - 06-19-2018, 08:47 AM
RE: Replacing a missing speaker - by Eric - 06-19-2018, 09:50 AM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 01:02 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-28-2018, 04:44 PM
RE: Replacing a missing speaker - by Eric - 06-28-2018, 10:07 PM
RE: Replacing a missing speaker - by Radioroslyn - 06-29-2018, 03:12 PM
RE: Replacing a missing speaker - by Eric - 06-30-2018, 10:14 AM
RE: Replacing a missing speaker - by Radioroslyn - 06-30-2018, 11:47 AM
RE: Replacing a missing speaker - by Eric - 07-02-2018, 03:44 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 02:56 PM
RE: Replacing a missing speaker - by Radioroslyn - 07-10-2018, 03:19 PM
RE: Replacing a missing speaker - by Eric - 07-10-2018, 05:06 PM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 09:54 AM
RE: Replacing a missing speaker - by KCMike - 07-12-2018, 10:11 AM
RE: Replacing a missing speaker - by Eric - 07-12-2018, 04:18 PM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 09:35 AM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 10:51 AM
RE: Replacing a missing speaker - by Eric - 07-14-2018, 05:01 PM
RE: Replacing a missing speaker - by KCMike - 07-14-2018, 07:03 PM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2748 online users. [Complete List]
» 1 Member(s) | 2747 Guest(s)
