  • 1 Vote(s) - 4 Average
*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
#83
yup,,
so i need to calibrate the power resistor....
i have a few ohmite adjustable R's but i just discovered a little while ago that the "GREEN" resistor in my pic in the lower right is actually a 50 ohm.
the two larger ones next to the green are soldered parallel to make 22 ohms which represents the one resistor with the lamp across it.
so.. on this green ressistor,,,
would you go less on ohms or more or the same?
i have 35 to 40v on the 6sq7 pin 6 when the set is cold but as i believe this resistor starts to get too hot ,, thats whats prob taking my pin 6 voltage down to around 11v,, ive watched it happen several times now.
thoughts....?
RE: Minerva Tropic Master model w117 "EARLY" - by jcassity - 06-30-2018, 12:46 AM
Users browsing this thread: 43 Guest(s)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7422 online users. [Complete List]
» 3 Member(s) | 7419 Guest(s)
