  • 1 Vote(s) - 4 Average
*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
#84
tom,,,
the power input to the rect tube is wired exactly as the schematic shows.
i gather your saying i should connect the ac line cord differently...? i think your saying connect my 120v lead to rect pins 3/5,, which is for the sake of wiring already done.
my 120v hot leg is tied to the "input side of the 40ohm first power resistor. from that same termination i have a jumper wire going to the rect pin 3/5.
the N leg is wired like the print.
are you saying to move the "cold side of my on/off switch N leg up to the rect tube pins 4/8?
effectively if yes, that would mean my N leg of the chord would be on the + side of the "left" filter cap.
random comment- the print tells me the on / off sw is controlling the N leg of my power cord. I find this kinda odd and backwards.
RE: Minerva Tropic Master model w117 "EARLY" - by jcassity - 06-30-2018, 10:24 AM
Users browsing this thread: 43 Guest(s)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7205 online users. [Complete List]
» 4 Member(s) | 7201 Guest(s)
AvatarAvatarAvatarAvatar
