  • 1 Vote(s) - 4 Average
*Solved Minerva Tropic Master model w117 "early"-crackle pop & no vol ****SOLVED
#87
****************I THINK I HAVE FOUND THE ISSUE
with no tube installed on the 6sq7, yet the filament pins 7 & 8 safely jumped,  PIN 6 of the 220k ohm resistor has about 20v which will degrade if i let it warm up. so the voltage will continue to decrease.
up to this point i have been lifting the side of the 220k ohm resistor at the 50L6 side which makes the noise / problem go away.
i kept the 220k ohm resistor terminated over at the 50L6 this time and lifted a cap and the 220k ohm resistor off the socket of the 6sq7 pin 6.
with no tube installed and filament pins 7 & 8 safely jumpered,  and with the 220k ohm resistor lifted off pin 6 of the 6sq7, my voltage readings are:
-the end of the 220k R tied to the 50L6 is 108vdc
-the free end up in the air that normally lives on pin 6  as i have pictured now reads 84vdc ***THIS IS THE VOLTAGE I need with the resistor terminated.
so as soon as i terminate the resistor back on pin 6, without a tube installed, the voltage will crash and drop.
sounding like a bad socket?????????
or bad solder joint(s)?? ~which i can easily reheat up and recheck.
see picture..
see the resistor and cap i lifted off pin 6
see the jumper wire setup (fused) to the right of the set on the bench to jump the 6sq7 socket filament pins 7 & 8.
RE: Minerva Tropic Master model w117 "EARLY" - by jcassity - 06-30-2018, 11:39 AM
Users browsing this thread: 40 Guest(s)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7010 online users. [Complete List]
» 4 Member(s) | 7006 Guest(s)
AvatarAvatarAvatarAvatar
