Need to replace Condenser
check this web page   https://www.justradios.com/cart.html   . Scroll down the center column. Use the .033 or the .05 MFD 250V Y2 safety cap. Either should do the trick.
Need to replace Condenser - by jbrune - 06-30-2018, 07:48 PM
RE: Need to replace Condenser - by mikethedruid - 06-30-2018, 08:37 PM
RE: Need to replace Condenser - by mikethedruid - 06-30-2018, 08:43 PM
RE: Need to replace Condenser - by Radioroslyn - 06-30-2018, 08:55 PM
RE: Need to replace Condenser - by Arran - 07-01-2018, 02:55 AM
91H Code 126 Restore
There are currently 2939 online users. [Complete List]
» 1 Member(s) | 2938 Guest(s)
