91D restoration
Sorry, I forgot to address your question about the escutcheon.
Assuming you are speaking of the brass piece surrounding the set's dial and shadow meter...It is held on by three screws, easily accessible from the front. Two near the top, one at the bottom. Just unscrew these small screws and remove the escutcheon. No need to look for something inside the cabinet to remove the escutcheon.
[Image: http://i326.photobucket.com/albums/k420/..._bezel.jpg]
The three screws are what the three white lines in the photo above are pointing to.
This is a close-up of my 18B. More info on your 18D may be found here:
http://www.philcoradio.com/gallery/1933c.htm#l
91D restoration - by Guest - 07-02-2010, 04:37 PM
Re: 91D restoration - by Chuck Schwark - 07-03-2010, 01:27 PM
Re: 91D restoration - by Ron Ramirez - 07-04-2010, 08:38 AM
Re: 91D restoration - by Guest - 07-04-2010, 10:50 AM
Re: 91D restoration - by Ron Ramirez - 07-04-2010, 12:30 PM
Re: 91D restoration - by Guest - 07-04-2010, 01:23 PM
Re: 91D restoration - by Ron Ramirez - 07-04-2010, 01:45 PM
Re: 91D restoration - by Guest - 07-05-2010, 03:34 PM
Re: 91D restoration - by Ron Ramirez - 07-05-2010, 03:38 PM
Re: 91D restoration - by Guest - 07-11-2010, 02:59 PM
Re: 91D restoration - by Ron Ramirez - 07-11-2010, 04:46 PM
Re: 18D restoration - by Guest - 07-11-2010, 08:39 PM
Re: 91D restoration - by Ron Ramirez - 07-11-2010, 09:35 PM
Re: 18D restoration - by Guest - 07-12-2010, 02:14 PM
Re: 18D restoration - by Guest - 07-13-2010, 07:53 PM
Re: 91D restoration - by Ron Ramirez - 07-13-2010, 08:25 PM
Re: 91D restoration - by TexMac - 07-18-2010, 02:31 PM
Re: 18D restoration - by Guest - 07-20-2010, 10:49 AM
There are currently 10464 online users. [Complete List]
» 2 Member(s) | 10462 Guest(s)
