Zenith 7G605 Transoceanic - the Clipper
to the heat and asbestos....
your auto parts store sells VHT spray paint and some up to 3000degF.
I would spray the fluid into the cap of the spray can,,, then brush it onto the asbestos.
pics for sure....
i have an early 80's transoceanic, love it.
RE: Zenith 7G605 Transoceanic - the Clipper - by jcassity - 07-02-2018, 10:34 AM
There are currently 8935 online users. [Complete List]
» 1 Member(s) | 8934 Guest(s)
